01-02-2006 10:51 AM
I am trying to figure out why my ISDN calls with Cisco 5400 DS3 connection to PBX failed with 'Normal call clearing'.
I am just wondering what is the maximum simultaneous ISDN call can Cisco 5400 support with DS3 connection.
Any help would be greatly appreciated.
George
01-03-2006 01:15 AM
I feel these datasheets on AS5400 will be of some help to u to pick out the performance related datas..
http://cisco.com/en/US/products/hw/univgate/ps505/products_data_sheet09186a0080091e51.html
http://cisco.com/en/US/products/hw/univgate/ps505/products_data_sheet0900aecd802efc92.html
regds
01-03-2006 11:36 AM
Thanks a lot. The listed concurrent call supported provides a clue for my problem.
One other thing I got confused is the IOS commands for AS5400. Not sure whether it has anything to do with the call fail.
When configuring controller T1, there is no linecode command as it has in AS5300. In AS5300, you can specify the linecode for T1 level, e.g
Linecode B8ZS. However there is no such command in AS 5400.
I assume the default must have been used. But when I do the show controller T1, there is no linecode information in it. Did I miss anything? Can anybody shed me a light? thanks in advance.
Here is the sh controller T1(I only see the Framing, no line code info):
Framing is ESF, Clock Source is Line.
Data in current interval (703 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
T1 7/0:3 is up.
Applique type is Channelized T1
No alarms detected.
alarm-trigger is not set
Version info of slot 7: HW: 768, PLD Rev: 1
Framer Version: 0x48
thanks
George
01-03-2006 05:39 PM
648. Need enough DSP resources on the NP108 cards. Show spe shows available.
01-04-2006 04:23 AM
Hi Jullal,
thanks a lot.
the sh spe shows me the total port is 540, does that mean this setting only support up to 540 concurrent calls?
Settings :
Country code config : default T1 (u Law)
History log events : 50(per port)
Legend :
Port state: (s)shutdown (r)recovery (t)test (a)active call
(b)busiedout (d)download (B)bad (p)busyout pending
Call type : (m)modem (d)digital (v)voice (f)fax-relay (_)not in u
Summary :
Ports : Total 540 In-use 27 Free 513 Disabled 0
Calls : Modem 0 Digital 0 Voice 27 Fax-relay 0
SPE SPE SPE SPE Port Call
SPE# Port # State Busyout Shut Crash State Type
2/00 0000-0005 ACTIVE 0 0 0 ______ ______
2/01 0006-0011 ACTIVE 0 0 0 ______ ______
2/02 0012-0017 ACTIVE 0 0 0 ______ ______
George
