12-06-2012 09:09 AM
we have a Lync2010 Server, that sends the following tel-uri in the SIP FROM field to a Cisco CUBE:
FROM: <sip:+43123456789;ext=10101@server;user=phone>;epid=37D3B7C02C;tag=ad7a0684d
I need to modify this tel-uri into a valid sip-uri like this: sip:+4312345678910101
I tried the Conditional SIP Header Manipulation feature but wasn´t sucessfull.
Is there any way, to modify the incoming FROM field from the lync with the ;ext= in it into a useful from-number with the extension?
Thanks, Gerhard
12-10-2012 06:52 AM
I solved the problem.
The important thing is to configure a copy-list at the incoming dial-peer and define the parameter you want to modify (at the outgoing dial-peer):
voice class sip-copylist 10
sip-header FROM
dial-peer voice 10 voip
description Call-Leg from Lync Mediation-Server1
voice-class sip copy-list 10
Then it is possible to modify the FROM field at the outgoing dial-peer:
voice class sip-profiles 101
request INVITE peer-header sip FROM copy "ext=(.....)@" u01
request INVITE sip-header From modify "(43123456789)" "\1\u01"
dial-peer voice 101 voip
description Call-Leg to SIP-Provider
voice-class sip profiles 101
Cheers, Gerhard
06-20-2013 11:15 PM
Hi Gerhard,
I know this post is pretty old but hope you can help me.
Did you manage to get the video working with this solution?
Hamed
07-02-2013 04:15 AM
Hi Hamed,
we had no video.
But you should be able to rewrite any parameter within the SIP header with this method.
Gerhard
