Cisco DTMF features, Adding prefix in Called number
bilaljaved
Dear Sir,
I have one more scenario problem if you please guide :
The scenario is i am reciving the call from PSTN on cisco gateway 5400 and which
forwards the call to softswitch. Now i am using two stage dialing for this scenario.
The customer called 1256 two stage code and cisco forwards that code to softswitch
which generates IVR for entering called number.
Now the called number is coming in DTMF. And when called number in DTMF reaches
softswitch it routes the call depending on its LCR which is based on called number.
Now i want that my Cisco 5400 append some prefix with dialed number so that my
softswitch then routes the call based on that prefix which is placed before called
number which is coming in DTMF.
Is this can be done in cisco Gw?
Please guide and suggest for any possibility.
Bilal
Maxim Denisov
Level 3
Level 3
Hello Bilal.
I don't know if it possible to append dtmf but why you don't just add this preix to 1256 using translation profile and match it on the softswitch?
Dear Denisov,
Actually 1256 is the code which generates IVR " enter called number " to calling party, and then my softsiwtch made routing decisions based on numbers which are coming in DTMF as called numbers.
Softswitch only make decision based on called number in DTMF not 1256, so that's why i cannot make it on 1256.
Can you please suggest more.
Bilal
