CLID question
robert.schira
I receive from TDM this string: 1111*2222.
first part is dnis (1111), second part should be clid (2222).
how can I setup this?
note: that is just an example, dnis and clid can be any digits (number is fixed though).
thank you.
LE: i cannot use 'clid network number'. Also it is CAS (e&m wink)
Tony Huynh
Level 4
Level 4
This can be accomplished using the FGB feature, which is only available on certain platforms.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1834/products_feature_guide09186a008007fe27.html
HTH,
Tony
Thanks a lot, that's what i was looking for.
I will test asap.
