CUBE and AS5400 - Billing on SIP trunk
richard.turian
what possibilities are there on CUBE (r3940) or AS5400 to enforce data for billing (CDR or any billing format).
There will be a SIP trunking between Contact Center and TELCO provider. Contact Center system (Genesys) is not able to handle forwarded / transfered calls, so as alternative of billing on CUBE or AS5400 is needed.
Thanks for response.
Richard
If your goal is to export CDR from a cisco gateway, you can use gw-accounting command:
gw-accounting
To enable an accounting method for collecting call detail  records (CDRs), use the gw-accounting command in global  configuration mode. To disable an accounting method, use the no form of this command.
gw-accounting {aaa | file | syslog [stats] }
no gw-accounting {aaa | file | syslog [stats] }
gw-accounting {h323 [vsa] | syslog | voip}
no gw-accounting {h323 [vsa] | syslog | voip}
Syntax Description
aaa
Enables  accounting through the AAA system and sends call  detail records to the  RADIUS server in the form of vendor-specific attributes  (VSAs).
file
Enables the file accounting method to store call detail  records in .csv format.
syslog
Enables the system logging facility to output accounting  information in the form of a system log message.
stats
(Optional) Enables voice quality statistics to be sent to the  system log.
h323
Enables standard H.323 accounting using Internet Engineering  Task Force (IETF) RADIUS attributes.
vsa
(Optional) Enables H.323 accounting using RADIUS VSAs.
voip
Enables generic gateway-specific accounting.
You can find more info in cisco IOS voice command reference guide.
This is an example to collect CDR of H.323 calls via RADIUS:
gw-accounting syslog
gw-accounting aaa
attribute acct-session-id overloaded
attribute h323-remote-id resolved
acct-template callhistory-detail
Regards.
