날짜: 06-15-2011 01:32 AM
We a working FoIP Implementation:
RightFax SR140, Intercluster-Trunk to CUCM 6.1.2, 2811 H.323 voice gateway with IOS 12.4(24)T3 to PSTN.
The problem is, outbound FAX to a FAX-Machine, that answers the call only after more than 15s will be disonnected, before the FAX gets answered.
We already checked all relevant timers on the gateway and the CallManager.
Anyone has an idea, why the gateway disconnects after 15s (voice service voip, h245 tcs timeout is already set to 45s, but the gateway still disconnects after 15s)?
We also tried IOS 12.4(24)T5 (actually the latest release running on this hardware), but the behaviour is the same.
날짜: 08-03-2011 04:48 AM
Hi Stefan,
Have you solved it?
I'm having problems with H323 and brooktrout SR140.
Sometimes with somefaxes I get Busy tone detected error and actually Remote Fax-Machine is not busy...
Thanks in advance
날짜: 08-08-2011 12:21 AM
Hi Manuel
Unfortunately the problem couldn't be solved so far.
We still have an open TAC-Case.
kind regards
Stefan Leder
SYMPANY
IT-Network- & Communication-Services
Peter Merian-Weg 4
4002 Basel
Direkt: +41 58 262 38 52
Fax: +41 58 262 42 01
stefan.leder@sympany.ch
www.sympany.ch <>>
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
