Dial-peer match everything except specific pattern
iMarkJavier
Level 3
Level 3
In my lab deployment, i'm using +e.164 pattern in the ITSP and DNs in CUCM. In the VG, i have the following outbound Dial-peer configured:
dial-peer 110 (to CUCM)
destination-pattern +1408555[0-4]...
dial-peer 210 (to ITSP)
destination-pattern +T
if dial-peer 110 failed, it is trying to send the call back out to PSTN. is it possible to create a pattern that can match everything except my DIDs?
Try to create a longer match pattern that matches your DNs and block these
calls to PSTN. Then have a wider pattern to send remaining calls to PSTN.
So you will have two dialpeers on PSTN, one to block your DIDs and the
other one to pass all DIDs.
***** please remember to rate useful posts
Hi Mohammed,
Can you please provide a sample configuration?
Mark
