Bookmark
Subscribe
574
DTMF-relay problem on IOS version 12.3(26)
ciscomanx
Hi NetPro:
I'm having dtmf problem on my AS5350 gateway. Previously im using version 12.3(3i) and wasn't able to make dtmf calls, i check Cisco Software Advisor and the feature is not there so i upgraded to IOS version 12.3(26) but unfortunately it doesn't work also.
Under the dial-peer configuration, when i issue "dtmf-relay ?" i can only see both h245 and the rtp-nte options. SIP-notify and cisco-rtp are not shown. Cisco says SIP NOTIFY-Based Out-of-Band DTMF Relay Support was introduced in 12.3(4)T release but im already using 12.3(26) which is the latest.
Gateway(config-dial-peer)#dtmf-relay ?
h245-alphanumeric DTMF Relay via H245 Alphanumeric IE
h245-signal DTMF Relay via H245 Signal IE
rtp-nte RTP Named Telephone Event RFC 2833
Do i need any other configuration to enable sip-notify?
I really appreciate your help and support.
Thank you.
pranabgaya
can u add the below line first .
gateway(config)# sip-ua
can u pls attach the running config .
