E1 Controller flapping..
mahindrasat
sh network-clocks
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          E1 0/0/0        GOOD            E1
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          E1 0/0/0        GOOD            E1
Sh controller e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (353 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     1 Line Code Violations, 1790 Path Code Violations,
     1 Slip Secs, 90 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
     44 Errored Secs, 4 Bursty Err Secs, 34 Severely Err Secs, 95 Unavail Secs
Even I got so many Input and CRC errors in Sh Inter se 0/0/0:15....
So please tell me excat solution....to resolve this issue
You can use commands "network-clock-participate" and "network-clock-select" to set synchronization parameters.
If the problem remains you can check the circuit with your telco.
Regards.
