every call is being dropped on the 5th minute
teodor.dobrev
Hi to all
Here is the problem
I have 2811 connected through WVIC-MFT-E1 to the telco using ISDN PRI service.
IPT using CCM 4.2.
Every call I made out and in to the PSTN gets dropped on the exactly 5th minute (300 sec) with cause code 127 interworking error
18F1 : 14740 882840880ms.14758 +160 +300900 pid:200 Answer 08070707#
dur 00:05:00 tx:14802/2486736 rx:14987/2397920 7F (interworking (127))
Telephony 3/0 (14740) [3/0] tx:278170/278170/0ms g711alaw noise:-67dBm acom:-29dBm
18F1 : 14742 882840950ms.14759 +90 +302820 pid:3334 Originate 600
dur 00:05:02 tx:14860/2377600 rx:14804/2368640 7F (interworking (127))
IP 192.168.5.29:16384 SRTP: off rtt:0ms pl:277790/0ms lost:0/2/0 delay:55/55/65ms g711alaw
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
I get slips on the line:
R2811-B#sh controllers e1 0/0/0
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Description: BTC_PRI_LINE
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20051006, FPGA: 20, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (788 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
8 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
8 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
And here is the configuration:
controller E1 0/0/0
linecoding hdb3
framing crc4
clock source line
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending round-robin
no cdp enable
end
The telco said that this is not their problem.
Any suggestion might be useful.
Thanks in advance
iostres
Hi!
Can you post "debug isdn q921" and "debug isdn q931" for a call?
Ivan
teodorgeorgiev
Level 4
Level 4
As suggested, post a Q.931 debug output here.
It is important to know which side drops the call with DC 127.
Might be the, CCM is sending some QSIG-ed facility to the gateway which is then transmitted to the ISDN link.
Hi to all,
I found the problem ? there is a pix between the call manager and phones network, and the gateway.This f? device was droping the udp connection after exactly 5 minutes because it is considering it as idle ? why? I don?t know
Thanks for the help to all that responded ? sorry I cant send debugs now because I obviously didn?t save any.
Have a great evening/day
