GW5350 controller clock setting
kieulam.nguyen
Hi All,
My GW5350 is running System image file "flash:c5350-is-mz.122-2.XB7.bin"
I have connected back2-back to a Vocaltec gateway, my test calls are good quality with short PDD, with my controller default clock source line.
However for testing purpose, I cannot find command to change clock source, even cannot issue command
Router(config-controller)#clock souce line primary
As reommended in Cisco document.
Please advise me how to change clock source for the controller E1 in Cicso GW5350.
Thanks.
Kieu.
5 Replies 5
arraman
Hi Kieu,
what is the error do you get?
Also there is a typo error "source" in the command you have copied.
Arun
Hello Arun,
Thanks for ur quick response, I cannot change the clock source for the controller when trying to connect back-to-back with Vocaltec gateway, here is the error:
HAN-5350(config)#controller e1 3/0
HAN-5350(config-controller)#clock source line primary
% Invalid input detected at '^' marker.
Kieu
in as5350/5400s setting the clock source is different. In global config, use the command "tdm clock priority Z x/y", where Z is from 1-99, and x/y the slot/port combination of the E1 controller.
Y.
Hi Fouraki,
My gateway 5350 doesn't recognize that command.
HAN-5350(config)#tdm?
% Unrecognized command
sorry, try dial-tdm-clock command
