H.323 payload header
aarizvi213
I am creating Voice Over IP scenario , in which I have to generate
call from one gateway to other gateway.
My question will be ver simple in this way :
I connected to private IP on ane side of the Router 1 and the other
side of ROUTER 1 is public IP . This Public IP is connected to the
Router 2 on Public IP.These Public IPs are different. I mean to say
that it can be come through ISP or I can create on same network.
I did NATting on ROuter 1 . I am able to ping from both side.
Remember NATTING is only on ROuter1 not in ROUTER 2
But the problem is that when I send H.323 packet I can able to reach
at the ROuter2 , but unable to get back to ROuter1.
The reason I found that natting change the Source and Destination
addresses of the outer side so its able to ping but not for the H.323
b/c in H.323 it put the Source and destination add on Payload , so
the packet is able to reach to the destination Router2 , but from
Router2 its unable to get back b/c ROuter2 will see the Source and
detination address of the payload side so it found the private adds
so unable to send back.
I found a solution by using PIX instead of using Router1 . In PIX , I
used a command fixup protocol h323 , so the pix even change the
source and destination add of the payload. So in this way I am able
to do it .
SO IS THERE ANY WAY IN ROUTER TO CHANGE THE SOURCE AND DESTINATION
ADD OF THE PAYLOAD AS PIX ARE DOING ???????
Please reply me as soon as possible.
ATIF
Chester Rieman
If I used 2500 or 2600 series router with IOS release 12.1 can work , right ????
I think 1700 series routers also support ????
