H323 POTs Dial_Peer causes loop need help
gfremgen
All,
   I have a layout with a call that is going to the following path PBX ->
(wink trunk)H323-GW -> CM -> SIP -> Telco All my calls work perfectly with the following dial-peers below. The poroblem I have is when a user calls a number that starts with 2, the call matches the dial-peer 2000 and send the call right back in. I do have delay on the other calls but I realize that is because I am not exact matching on the voip peers and using .T. Please let me know if any of you experienced this and what the work around is for it.
dial-peer voice 2000 pots
description Inbound to Troy PBX 2300-2439
preference 1
destination-pattern 2...
port 0/1/0:1
forward-digits all
dial-peer voice 3330 voip
preference 3
destination-pattern .T
modem passthrough nse codec g711ulaw
voice-class codec 1
voice-class h323 1
session target ipv4:10.70.33.30
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 3331 voip
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:10.70.33.31
fax rate disable
no vad
dial-peer voice 3390 voip
preference 3
voice-class codec 1
voice-class h323 1
session target ipv4:10.70.39.30
fax rate disable
no vad
dial-peer voice 1 pots
direct-inward-dial
ADAM CRISP
Level 4
Level 4
What happens if you change dial-peer 2000's destination to
destination-pattern 2...T ?
