How to add 2921 to Call Manger
gabiulici
Hiii,
I have a 2921 and is activated on the Lan, then I added the router to Call Manger from Device/Gateway/Add New/2921/MGCP/Domain Name/Module in Slot 0 ( NM-4WIC-MBRD ), then I activateda E1 to ( 0/0/0 ). How I can add the Gatway ( port -0/0/0 )  to a Route Group and what commands I have to do from the 2921 to be visible on the Call Manger.
On the Route Group/Find Device to Add to Route Group/ Device Name contains I don't see the ports from my 2921.
Did you follow the steps to add the GW in CUCM metioned on the links?
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Jorge Armijo
Level 4
Level 4
You have to configure few things on the MGCP GW:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
Then if you run into any issues:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805a316c.shtml
Jorge Armijo
Can you help me with the proper steps and what I miss from the commands in order to add the router to call manager and activite de E1 ports etcccc.
conf t
username admin priviledge 15 password XXXX
line vty 0  4
transport input all
login local
no access group xx
interface gi0/0
ip address X.X.X.X  Y.Y.Y.Y
no shutdown
hostname ....
mgcp
mgcp call-agent x.x.x.x.
ccm-manager config server x.x.x.x
ccm-manager config
ip route 0.0.0.0 0.0.0.0  gateway class
WR
conf terminal
no access-list 23
no banner login
wr
conf ter
card type e1
control e1 0/0/0
pri group timeslots 1-31 service mgcp
isdn switch-type primary-net5
metadata-clock-part wic
no ip domain name yourdomain.com
wr
Jorge Armijo
