09-25-2007 11:02 PM
Hi Forums,
I tried to call a destination number but failed.
I have this message logged using the debug voice ccapi inout, I tried to search for the disconnect cause, however I cant find it. Would really appreciate if anyone can help.
Sep 26 06:05:18.204: //253129/469D3310BBED/CCAPI/ccCallSetupRequest:
: Destination Pattern=66T, Called Number=66035277000, Digit Strip=FALSE
.Sep 26 06:05:28.440: //253129/469D3310BBED/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Thanks much,
Pnigel
09-26-2007 05:54 AM
Hi, at the next url you can find the codes:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094045.shtml#q931
Your code means a normal call clearing so I supposse it's not going to help you enough.
This url is very helpful because it tells you about troubleshooting a voip call.
Regards.
Hope this helps if so pls rate post
09-26-2007 07:48 AM
Dear Paul
Use the ISDN Cause Code, for CCAPI and ISDN are the same.
In this case : Cause Value=16 , 16 is Hexa and the table show :Number changed. The ISDN number used to set up the call is
not assigned to any system.
If you want, i can send to you a pdf with the table.
09-26-2007 07:55 AM
Sorry, in this case 16 is decimal value. Normal call clearing
09-26-2007 11:04 PM
Hi Christian, icabrera,
Thank you very much for your assistance. I am trying to read through the document.
Christian, I would be pleased if you can send me the ISDN cause code in PDF.
Thanks much,
Paul
10-26-2007 10:13 PM
hope this link is useful.
http://cisco.com/en/US/products/ps6441/products_command_reference_chapter09186a00804ab4b9.html
u can use "sh h323 gateway cause-codes"
regards
pranab
10-28-2007 05:16 PM
Hi Pranab,
Thank you very much for your help.
regards,
PN
