How to fix sip signaling port on Cisco 5400
amigo_nevermind
I have setup SIP connection on Cisco5400 and I face the problem "no ringing and call failed when destination accepted a call".
I have investigated this case with my partner and I find something wrong on SIP call flow as below
Cisco 5400               Partner
58090 INVITE ->        5060
5060 <- 100 Trying     5060
5060 <- 183               5060
53493 PRACK ->       5060
My signaling port always changed when send the signaling and I want to fix SIP signaling port to solve this problem but I don't know how to fix it.
Best regards,
Songtham
Commands are:
1. enable
2. configure terminal
3. voice service voip
4. sip
5. listen-port {non-secure | secure} port-number
Cisco uses 5060 as default.
These commands were introduced only in latest IOS versions and, if I correctly remember, are not supported from AS5400.
What IOS version is installed on your gateway?
Regards.
Hi Daniele,
My IOS is 12.3 (22)
Best regards,
Songtham
Can you upgrade the IOS to 12.4 version?
Hi Daniele,
I'll check all impacts related upgrading before do it. If I have any update I'll report on this topic again, thank you for your help
