Identifying oice traffic using ACL's
s.nasheet
Hi ,
Can you please advise how to identify Voice traffic using ACL's.
I need to identify voice traffic and then use route map to route traffic over preferred path.
Any sample config will help.
thanks
6 Replies 6
virverma
Level 4
Level 4
You can try this,
you can use this ACL to pick up voice and H323 signalling packets.
access-list 102 permit udp any any range 16384 37276
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any eq 1720
Where,
access-list 102 matches VoIP traffic based on the UDP port range.
access-list 103 matches VoIP signaling protocol. In this case, H.323 V2 is uesd with the
fast start feature.
Then we just need to apply this to a route-map and the interface:
a) Define a route-map for traffic to go to next-hop 6.6.6.6
route-map equal-access permit 10
match ip address 102
set ip default next-hop 6.6.6.6
route-map equal-access permit 20
match ip address 103
b) apply it to the inside (where the voice is connected to) interface:
int Ethernet0/0
ip policy route-map equal-access
Many thanks for the response.
Just want to confirm that using these acl line , if I mark all above UDP and TCP port , then all voice traffic will be catch by these ACL.
I am asking becasue in VOICE there are many other protocols. like SIP, TRP .
all I can say, voice traffic works on ports,
so you can try mentioning different ports
thanks
Let me know as well if the other way works,
Yes mate, will do.
