IVR autoload
lfplaimer
Im configuring a AS5350 to force the load of audios (used by a call application) using the ivr autoload command.
the command follows:
#ivr autoload mode verbose retry 3 url tftp://ppsvr01.telenova.com/IVR/telenova/ivr_autoload-br-en-sp-ch.txt
#ivr prompt memory 13000
my ivr_autoload-br-en-sp-ch.txt:
#GC
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_000.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_001.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_001_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_001_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_002.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_002_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_002_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_003.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_004.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_005.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_006.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_007.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_008.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_009.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_010.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_011.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_012.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_013.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_014.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_015.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_016.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_017.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_018.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_019.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_020.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_030.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_040.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_050.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_060.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_070.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_080.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_090.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_1.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_200.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_200_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_200_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_2.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_300.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_300_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_300_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_3.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_500.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_500_f.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_500_m.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_account_blocked.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_and.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_ani.au
tftp://ccptftp.telehumana.com/IVR/telenova/br_goodcard11/br_ani_confirm1.au
my call application loads the audio as follows:
call application voice ccp_goodcard set-location br 0 tftp://ppsvr01.telenova.com/IVR/telenova/br_goodcard11/
Thanks for the help.
5 Replies 5
paolo bevilacqua
And the question is ?
Sorry, forgot about the question...
The question is.. its not working.
The audio does not loads in after a reload, only when I call the gateway (the firt call fails because the audio is not loaded, and the second call works, once he loaded the audio in the first call)
Seems like a bug, you can try upgrading IOS or live with this minor problem.
Is the configuration correct ?
I want to be sure about it before update my IOS.
The "call application" are obsolete, use "aaplication" and "service". Not sure about "ivr autoload".
