IPIPGW on 72xx VXR
roymd
I'd like to know the specs of IP-to-IP GW IOS feature on 72xx VXR. Had been browsing for a while now looking for the specs for maximum simultaneous calls that a 72xx VXR can handle using the IP-to-IP gateway feature. Biggest box documented was a 3745 which can do 500. Anybody else seen the upper limit for 72xx?
This doesn't seem to be a complete list:
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_data_sheet09186a00801da698.html
I'd be glad if somebody can point me out to a newer documentation regarding the feature.
roy
nmilojevic
Hi Roy!
As far as I know, IP2IP GW feature is not supported on 7200 series. Where did you get the information, that this is possible?
Nikola
P.S. I checked - according to the Feature Navigator, IP2IP GW in NOT supported on 7200.
