IPIPGW SIP trunk to Mitel fails
g.sperryn
I need to setup a SIP trunk to Mitel. I have an IPIPgw providing SIP-H323 conversion. calls from the Mitel to CCM work fine, but calls from CCM to Mitel get dropped. debug on IPIPGW shows that SIP Invite gets sent to Mitel, but SIP 480 message gets sent back. the phone that we are trying to call does in fact ring once before the 480 comes back, and the debug shows the correct numbers going across in the invite.
all help appreciated!
SIP debugs for outbound call from IPIPGW to Mitel (names removed):
1w0d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:9000@10.222.254.11:5060 SIP/2.0
Via: SIP/2.0/UDP 10.68.64.49:5060;branch=z9hG4bK2DE4B
From: "xxx xxx" <sip:54885@10.68.64.49>;tag=246FF58B-1D2A
To: <sip:9000@10.222.254.11>
Date: Fri, 08 Mar 2002 04:26:43 GMT
Call-ID: 8783BD45-318311D6-942AFD43-B9363386@10.68.64.49
Supported: 100rel,timer
Min-SE: 1800
Cisco-Guid: 14282785-1227084061-1460142080-3232269354
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: "xxx xxx" <sip:54885@10.68.64.49>;party=calling;screen=yes;privacy=off
Timestamp: 1015561603
Contact: <sip:54885@10.68.64.49:5060>
Expires: 180
Allow-Events: telephone-event
Received:
SIP/2.0 100 Trying
To: <sip:9000@10.222.254.11>;tag=MitelICP_2360753296-56820724
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 480 Temporarily Unavailable
CSeq: 101 INVITE
Contact: <sip:10.222.254.11>
Content-Length: 0
6 Replies 6
teodorgeorgiev
Level 4
Level 4
I am 80% sure that this is due to codec negotiation problems.
Check the configured codecs all along the path.
Unfortunately I do not see the Cisco offering any codecs to Mitel in the INVITE message.
There should be a set of a=rtpmap lines with the preferred codecs.
yeah my first thought was codecs too.
codec is set as g711a for inbound and outbound dialpeers.
what would make an IPIPgw not send codec info?
I would try setting codec transparent for ip-to-ip gw. It is strange it is not sending a= lines in sip invite. Peraphs if you enable debug cch323 it would be possible to see what the CM is sending.
Thanks I will try the transparent codec
please see attached debug
ipipgw
ccsip
cch323
transparent codec makes no difference
I see that you are also using a GK and that is possibly complicating the issue. In the debug, looks like CCM is not specifying a codec:
1w0d: //105/00D9F0215708/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec bytes: 0
Compare that with a successful GK/GW call where a codec is specified:
http://cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00800a9a56.shtml
You may need to check CCM/GK configuration and take traces on CCM. Also, if you repost in "IP telephony" forum you may get a better answer as there are more CCM experts in there.
