Is there a cheat for setting up IPSLA on a ASR 1006 to Solarwinds?
johngalek
I have spent a considerable amount looking through Solarwinds docs and Cisco Docs but neither compliment each other. I have spent a ton of time adding and removing IPSLA parameters with no luck?  I am trying to setup all VoIP SIP parameters including- MOS jitter latency and packet loss for ASR 1006 routers rls. 16.6 software and Call Managers from 10.5 to 12.5 with 4 clusters.  Any help would be appreciated?  I am surprised there is no cheat there is a ton of Cisco and solarwinds products out on the market?
7 Replies 7
balaji.bandi
what is your existing config, " I have spent a ton of time adding and removing IPSLA parameters with no luck?"  - not sure the goal of your target, can you clear what you looking to achieve  ?
BB
johngalek
@balaji.bandiMy goal is to get the IPSLA parameters to register with Solarwinds for alerts and notifications for our Voice Network. We have 7 cubes with different service providers, the business wants to monitor the voice traffic traversing the cubes in Solarwinds to see if we are having issues. SIP statistics, Failed calls etc. VoiP Call Setup monitoring
Solarwinds VNQM v2022.3 which allows you to setup the gateways and the call managers. To see if we are having network issues on the agent side or VPN or Provider.. there are many things to be monitored.
I am New in VoIP but your idea is basic,
using the IP SLA jitter to increase the VoIP quality.
can you share the config, I will make review
Thanks, The configuration don't work but here it is. I have backed everything out and started with the basics,  ICMP echo & a ip sla responder. 172.30.x.xxx, SNMP v3 and Community string
version 16.6
service tcp-keepalives-in
service tcp-keepalives-out
rtcp all-pass-through
media statistics
allow-connections sip to sip
redirect ip2ip
signaling forward unconditional
call-quality
clock-rate dvi4 1500
clock-rate dynamic-default 10000
sip
header-passing
error-passthru
p access-list extended VHT
permit ip any any
ip sla responder
ip sla responder udp-echo ipaddress 172.30.x.xxx port 1023
ip sla responder udp-echo ipaddress 172.30.x.xxx port 1023 vrf Mgmt-intf
ip sla 1
icmp-echo 172.31.Solarwinds
frequency 300
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 172.30.ASR ROUTER source-ip 172.30.ASR router (Another ASR router ip sla responder)
request-data-size 64
tos 160
owner SW
tag VHT1poll 2
timeout 10000
frequency 30
history hours-of-statistics-kept 1
logging history informational
logging alarm informational
logging trap debugging
logging origin-id hostname
logging host 172.31.solarwinds
logging host 172.30.ASR router
snmp-server group NET_GROUP v3 auth write SW
snmp-server group NET_GROUP v3 priv write SW
snmp-server community private RW
snmp-server community xxxxxxxx RW
snmp-server trap timestamp
snmp-server trap-source GigabitEthernet0/0/0
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps pfr
snmp-server enable traps flowmon
snmp-server enable traps ds1
snmp-server enable traps entity-perf throughput-notif
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps casa
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps smart-license
snmp-server enable traps license
snmp-server enable traps atm subif
snmp-server enable traps bfd
snmp-server enable traps memory bufferpeak
snmp-server enable traps config-copy
nmp-server enable traps config-ctid
snmp-server enable traps dial
snmp-server enable traps diameter
snmp-server enable traps dlsw
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps dsp video-usage
snmp-server enable traps dsp video-out-of-resource
snmp-server enable traps fru-ctrl
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps pki
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps ethernet evc status create delete
snmp-server enable traps ether-oam
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps entity-qfp mem-res-thresh throughput-notif
snmp-server enable traps entity-state
snmp-server enable traps entity-sensor
snmp-server enable traps flash insertion removal lowspace
snmp-server enable traps firewall serverstatus
snmp-server enable traps netsync
snmp-server enable traps sbc adj-status
snmp-server enable traps sbc blacklist
snmp-server enable traps sbc congestion-alarm
snmp-server enable traps sbc h248-ctrlr-status
snmp-server enable traps sbc media-source
snmp-server enable traps sbc radius-conn-status
snmp-server enable traps sbc sla-violation
snmp-server enable traps sbc sla-violation-rev1
snmp-server enable traps sbc svc-state
snmp-server enable traps sbc qos-statistics
snmp-server enable traps srp
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps cnpd
snmp-server enable traps entity-diag boot-up-fail hm-test-recover hm-thresh-reached scheduled-test-fail
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps sonet
snmp-server enable traps resource-policy
snmp-server enable traps otn
snmp-server enable traps ip local pool
snmp-server enable traps trustsec-sxp conn-srcaddr-err msg-parse-err conn-config-err binding-err conn-up conn-down binding-expn-fail oper-nodeid-change binding-conflict
snmp-server enable traps lisp
snmp-server enable traps aaa_server
snmp-server enable traps dhcp
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps pw vc
snmp-server enable traps mpls rfc ldp
snmp-server enable traps mpls ldp
snmp-server enable traps mpls rfc traffic-eng
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps rsvp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps mvpn
snmp-server enable traps pimstdmib neighbor-loss invalid-register invalid-join-prune rp-mapping-change interface-election
snmp-server enable traps isis
snmp-server enable traps bgp cbgp2
snmp-server enable traps ospfv3 state-change
snmp-server enable traps ospfv3 errors
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps ike policy add
snmp-server enable traps ike policy delete
snmp-server enable traps ike tunnel startnmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps gdoi gm-start-registration
snmp-server enable traps gdoi gm-registration-complete
snmp-server enable traps gdoi gm-re-register
snmp-server enable traps gdoi gm-rekey-rcvd
snmp-server enable traps gdoi gm-rekey-fail
snmp-server enable traps gdoi ks-rekey-pushed
snmp-server enable traps gdoi gm-incomplete-cfg
snmp-server enable traps gdoi ks-no-rsa-keys
snmp-server enable traps gdoi ks-new-registration
snmp-server enable traps gdoi ks-reg-complete
snmp-server enable traps gdoi ks-role-change
snmp-server enable traps gdoi ks-gm-deleted
snmp-server enable traps gdoi ks-peer-reachable
snmp-server enable traps gdoi ks-peer-unreachable
snmp-server enable traps bulkstat collection transfer
nmp-server enable traps alarms informational
snmp-server enable traps voice
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps rf
snmp-server enable traps transceiver all
snmp-server enable traps mpls vpn
snmp-server enable traps mpls rfc vpn
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vn
snmp-server host 172.31.solarwinds community string xxxxxxx
snmp-server host 172.31.Solarwinds
snmp-server host 172.31.solar winds version 3 priv wanadmin
snmp-server host 172.31.tacinternal version 3 priv wanadmin
snmp-server manager
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/15-mt/sla-15-mt-book/sla_udp_jitter.html
the IP SLA have two end
source and responder, I think the ASR must be source and other Peer must be responder.
what you config is ASR as responder
I have a primary ASR as the source and yes I have a secondary ASR as the IP SLA responder.  My issue is that this does not register with the Solarwinds Network monitoring tool.
johngalek
Ok I have udp jitter working and MOS/jitter/latency/packet loss, however this is not registering in SW?  what the heck is missing?
phx1-r1r1-cube4-vht1#debug ip sla trace
phx1-r1r1-cube4-vht1#debug ip sla error
phx1-r1r1-cube4-vht1#show ip sla statistics 3
IPSLAs Latest Operation Statistics
IPSLA operation id: 3
Type of operation: udp-jitter
Latest RTT: 1 milliseconds
Latest operation start time: 09:50:29 Arizona Wed Nov 23 2022
Latest operation return code: OK
RTT Values:
Number Of RTT: 1000 RTT Min/Avg/Max: 1/1/6 milliseconds
Latency one-way time:
Number of Latency one-way Samples: 169
Source to Destination Latency one way Min/Avg/Max: 0/0/0 milliseconds
Destination to Source Latency one way Min/Avg/Max: 1/1/2 milliseconds
Jitter Time:
Number of SD Jitter Samples: 999
Number of DS Jitter Samples: 999
Source to Destination Jitter Min/Avg/Max: 0/1/1 milliseconds
Destination to Source Jitter Min/Avg/Max: 0/1/6 milliseconds
Over Threshold:
Number Of RTT Over Threshold: 0 (0%)
Packet Loss Values:
Loss Source to Destination: 0
Source to Destination Loss Periods Number: 0
Source to Destination Loss Period Length Min/Max: 0/0
Source to Destination Inter Loss Period Length Min/Max: 0/0
Loss Destination to Source: 0
Destination to Source Loss Periods Number: 0
Destination to Source Loss Period Length Min/Max: 0/0
Destination to Source Inter Loss Period Length Min/Max: 0/0
Out Of Sequence: 0 Tail Drop: 0
Packet Late Arrival: 0 Packet Skipped: 0
Voice Score Values:
Calculated Planning Impairment Factor (ICPIF): 1
MOS score: 4.34
Number of successes: 3
Number of failures: 0
Operation time to live: Forever
