Memory Issues ?
jack.richardson
Community Member
Every couple of weeks our CCM starts blocking outbound calling (call drops and users get a busy tone). This was verified with cellulare phones for testing. The only Alarms in the real-time monitoring relate to low available memory and LowTCDServerHeartbeat. Could this be characteristic of low physical memory on the CCM? The contractor that did the installation used the minimum 512mb for both CCMs which support a max of 250 configured employees. What else may be a cause of permitted inbound but denied outbound calling ?
milay
You have to provide more info. The LowTCDServerHeartbeat could be a result of low RAM or hight CPU. You would really need to look @ some perfmons for PrivateBytes, all processes & the CPU utilization for all processes.
I am assuming that you are using 7815I servers??? Regardless of the hardware platform 512M RAM is really not enough. This is even more true if you are running MLA or 4.x CCM.
Mike
Should have included that info in my posting, sorry. They were installed on the IBM 340 series platform and using CCM 4.0. The memory as viewed in RTMT is constantly at +99% on both servers. I was kind of thinking about the methodology that may have been used for the call processing, what would be dropped first in the event of maxed hardware resources, outbound before inbound calling, etc.
The minimum supported RAM for an IBM 340 server is 1G:
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd80091615.html
IBM xSeries 340 Pentium III 1GHz
The xSeries 340 is a robust server solution designed for Cisco IP telephony software applications. When clustered properly, 10,000 users can be supported. The required processor is an Intel Pentium III 1GHz processor. No specific memory configuration is required as long as 1GB of memory is achieved.
Table 5. Hardware for IBM xSeries 340 Pentium III 1 GHz
Qty.
IBM Part Number
Description
1 86566RY X340 1000 256 128/Open 24X
2 37L7205 18.2 Ultra 160 SCSI HS SL HD
1 10K0018 128MB ECC SDRAM RDIMM Memory
1 10K0020 256MB ECC SDRAM RDIMM Memory
1 10K0022 512MB ECC SDRAM RDIMM Memory
1 06P5740 ServerRAID-4Lx Ultra 160 SCSI
1 37L6880 270W Redundant Power Supply
1 00N7991 20/40GB DDS/4 4mm Int Tape Drive (Optional)
Mike
