Mitel 5360 IP Phones on Cisco 4506E
I need to connect up to 30 Mitel 5360 IP Phones to an existing Cisco 4506E with WS-X45-SUP6-E installed.
They will all be connected to WS-X4548-RJ45V+
Does anyone have a recommended configuration example?
Looks like this version "12.2(50)SG" of IOS has no "mls qos" command.
Any help greatly appreciated.
chrihussey
I have a 6L-E, so if they are the same:
Don't know about the Mitel phones, but for starters if they don't do CDP, you may need to have to enable LLDP if you are using a voice VLAN.
As far as QoS is concerned, you should be able to configure auto qos. In interface configuration mode try the "auto qos voip trust" command. It will auto generate a lot of policies and add configurations to the interface.
The other choice would be to configure your own policies and apply that to the interfaces. Here's an example:
class-map match-any NET-MGMT-SIG
  match  dscp cs7
  match  dscp cs6
  match  dscp cs3
  match  dscp cs2
class-map match-any PRIORITY
  match  dscp ef
  match  dscp cs4
class-map match-any VIDEO-CONF
  match  dscp af41
policy-map QOS-POLICY
 class PRIORITY
    priority
    police cir percent 30 bc 33 ms
      conform-action transmit
      exceed-action drop
 class NET-MGMT-SIG
    bandwidth percent 10
 class VIDEO-CONF
 class class-default
    bandwidth percent 50
    dbl
Then apply this as an outbound on the interfaces as well as inbound trust:
interface GigabitEthernet3/1
 service-policy output QOS-POLICY
 qos trust extend
Mind you, this is of course the Mitel phones are using the standard markings for voice (EF) and voice signaling (CS3). If otherwise adjust accordingly.
Hope this helps.
Thanks. Looks like Mitel phones support CDP. Yes I used auto qos.
Below is what I currently have as a config. When the phones arrive, I will test and look for the standard markings (EF) and signaling.
class-map match-all AutoQos-VoIP-Control-Dscp26
match  dscp af31
class-map match-all AutoQos-VoIP-Control-Dscp24
match  dscp cs3
class-map match-all AutoQos-VoIP-Bearer-Cos
match cos  5
class-map match-all AutoQos-VoIP-Control-QosGroup24
match qos-group 24
class-map match-all AutoQos-VoIP-Control-QosGroup26
match qos-group 26
class-map match-all AutoQos-VoIP-Bearer-QosGroup
match qos-group 46
class-map match-all AutoQos-VoIP-Bearer-Dscp
match  dscp ef
class-map match-all AutoQos-VoIP-Control-Cos
match cos  3
policy-map AutoQos-VoIP-Input-Dscp-Policy
class AutoQos-VoIP-Bearer-Dscp
  set qos-group 46
class AutoQos-VoIP-Control-Dscp26
  set qos-group 26
class AutoQos-VoIP-Control-Dscp24
  set qos-group 24
policy-map AutoQos-VoIP-Input-Cos-Policy
class AutoQos-VoIP-Bearer-Cos
  set qos-group 46
class AutoQos-VoIP-Control-Cos
  set qos-group 24
policy-map AutoQos-VoIP-Output-Policy
class AutoQos-VoIP-Bearer-QosGroup
  set dscp ef
  set cos 5
    priority
    police cir percent 33
class AutoQos-VoIP-Control-QosGroup26
  set dscp af31
  set cos 3
    bandwidth remaining percent 5
class AutoQos-VoIP-Control-QosGroup24
  set dscp cs3
  set cos 3
class class-default
    dbl
switchport access vlan 12
switchport voice vlan 13
switchport priority extend trust
auto qos voip trust
qos trust extend
spanning-tree portfast
service-policy input AutoQos-VoIP-Input-Cos-Policy
service-policy output AutoQos-VoIP-Output-Policy
Yep. You should be in good shape. Good luck.
