Nature of Address (NOA) - Cisco
ychuan
Hi all,
How can I set the NOA = subscriber instead of National or International?? on Cisco 5350?
Is there any translation for it?
regards
Hi i.fouraki,
I tested the numbering-plan on my voip dial peer and got this error:
4d05h: %CALL_CONTROL-6-NUMBERING_TYPE_NO_MATCH: The called number numbering type did not matchThe event for the callid 5411789 is being discarded.
Is there something wrong?
regards
vsergeyev
Did you try "isdn map ..." command on interface S X/X:15 for isdn numbers?
