Need help with AS5300
epesliak
We have been running AS5300 for a number of years with no problem. But had to reboot it lately (after 2 years) and it does not come back up. Gives us the following on the screen:
System Bootstrap, Version 11.2(9)XA, RELEASE SOFTWARE (fc2)
Copyright (c) 1997 by cisco Systems, Inc.
AS5300 platform with 131072 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x1781dc
Self decompressing the image : #################################################
####################################################################### [OK]
and than hangs...
What could it be? Any help?
Thank you.
b.hsu
Level 5
Level 5
The issue may be due to newly installed module which has no sufficient iomemory to hold that module.
increase iomemory by issuing the command
memio<>
The memory can be increased to 10,15 or 20 percent.
