Default Codec on 7912G
moorep6cco
Running Callmanager Express 3.3 on 2800 hardware. When calling between sites, using 7960 handsets, quality of call is perfect, using 7912G to 7960, very poor quality. I have read that the 7912G defaults to G.711 codec unless you enable g.729. Can anyone confirm this, and if thats right, how do you change it (profile ? webpage ?)
7 Replies 7
tbramwe
Level 3
Level 3
All devices in your CME group should use the same codec as set in the DSPfarm. 7912, 7940, 7960, etc.. should not vary unless they are in a different CME group.
The command should be
Router(config-dspfarm-profile)# codec g711ulaw
I believe this to be true in 3.3, as the doc indicates transcoding for g.729 was only between two-party calls in 3.2 and prior.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad867.html
Hope that helps.
Tom
Sorry, perhaps I didnt make it very clear. The problems are between 2 CME system, over a wide area link. I assumed that selecting the codec in the dial-peer statement was enough to ensure that g729 was used, but I dont think it is - hence the quality problems.
Anything anyone can add to that ?
Did you configure the router in global mode to use 729 also?
Try this:
Router#conf term
Router(config)#voice class codec 99
Router(config-class)#codec preference 1 g729r8
Router(config-class)#codec preference 2 g711ulaw
Router(config-class)#end
Then assign 729 to the dial-peer as well.
See if that helps.
Thanks, I will apply and test. Do you know any way of checking the codec used in an active call ? (sorry if thats a stupid question)
Pete
Pete:
Use 'sho call active voice' on the router from privileged mode.
... and I was told by a very wise man once that the only stupid question is the one that doesn't get asked.
Tom
Oh :( that blows that idea then; looks like we are using 729r8, so thats not my problem. Still cant understand why calls between 7960's are working but calls to 7912's are jittering.
output from show command:
Router# sho call active voice
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
GENERIC:
SetupTime=1868195990 ms
Index=1
PeerAddress=771
PeerSubAddress=
PeerId=20001
PeerIfIndex=39
LogicalIfIndex=38
ConnectTime=1868200590 ms
CallDuration=00:00:46 sec
CallState=4
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=1150
ReceiveBytes=46000
TELE:
ConnectionId=[0x58CEC485 0x4CA311DB 0x833B8EBE 0x6294392]
IncomingConnectionId=[0x58CEC485 0x4CA311DB 0x833B8EBE 0x6294392]
CallID=516
TxDuration=39320 ms
VoiceTxDuration=39320 ms
FaxTxDuration=0 ms
CoderTypeRate=g729r8
NoiseLevel=0
ACOMLevel=0
OutSignalLevel=0
InSignalLevel=0
InfoActivity=2
ERLLevel=0
SessionTarget=
ImgPages=0
CallerName=Pete Moore
CallerIDBlocked=False
OriginalCallingNumber=771
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=771
TranslatedCallingOctet=0x0
TranslatedCalledNumber=
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwCollectedCalledNumber=100108
GwReceivedCallingNumber=771
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x0
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
The number of call legs at the end of the show process
is not equal to the initial count. Some call-legs were
terminated or created during the viewing process.
Number of call-legs counted during viewing: 1
Pete:
This may seem strange to ask, but we ran into it once. Are your user's network ports nailed-up to a specific speed and duplex?
The 7912G is not able to be hard set to a speed or duplex - auto is the only option. The 7940/60G is able to be set and, as a result, reduced the duplex mismatches we were getting in our environment. Call quality improved, too.
Just a thought.
Tom
