Only class-default supported over FR VCs?????
raul-morata
Hi friends,
When I apply a "class" over a frame-relay subinterface i obtain the nex error message: Only class-default supported over FR VCs..
I am implementing a QoS feature on my routers.
Brandon Buffin
You will need to use a hierarchical service policy. As stated in the following document, "You must create a default class for the service policy as specified with the class class-default command to configure FRTS using MQC on a Frame Relay PVC." The following link should help.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110bc6.html
Hope this helps. If so, please rate the post.
Brandon
