Preference 1 POTS Dial peer Outbound state is down
yavuz_sab
3845 12.3(11)T7
Currently have 3 x E1 PRI terminating for Outbound and Inbound on our 3845.
I have configured 3 x Preference POTS dial-peers for redundancy/load balancing purposes.
Not sure why, but my first preference POTS dial peers Outbound Status is DOWN for voice port 0/1/1:15 which is using c5510 DSP PVDM2-64 inside the chassis. For my preference 2 POTS dial-peer for port 3/0/0:15 is using the c549 DSP on NM-HDV the status is UP.
Here is a sh dial-peer voice summ
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
6689 pots up up 1[8-9]T 1 down 0/1/1:15
6666 pots up up 04........ 1 down 0/1/1:15
108 pots up up 00111.......... 3 up 3/0/0:15
5566 pots up up 0[2-9]........ 1 down 0/1/1:15
5565 pots up up 0[2-9]........ 2 up 3/0/0:15
6655 pots up up 04........ 2 up 3/0/0:15
9 pots up up 0.T 2 up 3/0/0:15
I checked the status of the voice-port and dial peers and there up and operational.
Is there something i am missing or misconfigured?
Please assist me on this one.
Cheers!
Yavuz
yavuz_sab
Thats fine! I think i figured the problem out. Let alone the dial peers down Our E1 controller is DOWN :-(.
Currently investigating the problem. Under the E1 controller receiving the following "Receiver is getting AIS". From what i can gather seems to relate to Telco switch issue.
-Yavuz
i had the same problem using one 2811 with IOS 12.3.11T7 and i solve it upgrading to the 12.3.14T5.
Carlos
