problem on VIC2-2BRI-NT/TE Sometimes Can´t make calls
r.morales
I have configured this card, and some times Cant receive calls and some times can´t make calls, and to make calls again just receive a call, and now can make calls for little moment. What can be the problem?
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn static-tei 0
voice-port 0/2/0
compand-type a-law
cptone MX
dial-peer voice 100 pots
destination-pattern .T
direct-inward-dial
port 0/2/0
forward-digits all
dial-peer voice 3 voip
progress_ind setup enable 3
voice-class codec 1
session target ras
ip qos dscp cs5 media
ip qos dscp cs5 signaling
iostres
Try "no dial-peer outbound status-check pots" in global configuration mode.
Ivan
sdeltoro1
I have tried it and really worked, thanks a lot of
Well, you could rate my post if it was helpful ;-).
Ivan
