Problem sending faxes through VoIP
ramosmarco
Hello every one!
I have a problem sending faxes through VoIP
This is what we have:
PBX with VoIP Card --- Cisco --- E1 --- (Internet VPN) --- T1--- Cisco --- PBX
The cisco router has activate the QoS, to priority the communication saving 512 kbps of bandwidth, for the matching VoIP ports.
The voice and faxes work fine, but when the bandwidth is over use, the voice is not affected but the faxes can not communicate even when the QoS is saving bandwidth for them. I been trying with traffic-shape, fax passthrough , fax relay and other options, but no one fix the problem.
I figure out that the cisco router is working only as data gateway not as voice gateway, because the VoIP card in the PBX is making job, so may I?m look to solve the problem in the wrong place.
The VoIP card is configured by a provider, but I try changing the communication options between G.729, G723 and G.711, when use G.711 the voice is better, but the same happen with the faxes.
The question is:
Do I have to correct the fax problem in the VoIP card configuration or is possible to fixed in the cisco Router?
If it can be in the Cisco router, I will appreciate any suggestion.
Thank you very much, regards.
thomas.chen
Level 6
Level 6
The issue is due to slips on the 2811's T1 Controller. Whilethese won't bother voice calls they will prevent modem and fax calls from completing.
Try adding the following
network-clock-select 1 t1 0/0/0
controller T1 0/0/0
clock source line primary
Clear the counters and see if you see the slips continue to increment on the 'showcontrollers t1'
Add the following to both the VG224 and the 2811
no mgcp fax-relay sg3-to-g3
mgcp fax t38 inhibit
no mgcp fax t38 ecm
no ccm-manager fax protocol cisco
Thank you so much,
I been trying to configure you recomendation, but I can?t find the network-clock-select command, I looked it into the general and interface configuration, but it?s not there, I don?t understand why because it support that this command must to be in the Cisco OS version that I?m using.
Do you know if I have to enable some module or update the OS in order to use that command?
Here is the system information.
IOS (tm) C2600 Software (C2600-IK8O3S-M), Version 12.2(11)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 01-Aug-02 12:47 by ccai
Image text-base: 0x8000809C, data-base: 0x818188F4
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
router2600_2 uptime is 4 weeks, 2 days, 23 hours, 23 minutes
System restarted at 18:49:47 PDT Fri Aug 25 2006
System image file is "flash:c2600-ik8o3s-mz.122-11.T.bin"
cisco 2610 (MPC860) processor (revision 0x300) with 61440K/4096K bytes of memory.
Processor board ID JAD05490ZBG (3906121021)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Best regards,
jcastilloz
You can try also configuring the following commands under the dial-peer voip you are using for fax calls:
fax-relay ecm disable
fax rate 7200
fax nsf 000000
Some faxes don't work fine when error correction mode is enable. hope could be helpful.
Regards.
