SRST problem with BRI
alvader
Hello
A have a problem with my SRST configuration.
I have a 2821 with the SRST feature configured and the router has one BRI to route the calls out when SRST is enable.
My problem is that the call to outside not work. The IP phones registered with the router right and tha internal calls work fine, but when i try to make a outside call throught the ISDN the call does not complete.
The configuration is the next:
call-manager-fallback
max-conferences 8 gain -6
user-locale ES
timeouts interdigit 2
ip source-address 172.20.22.2 port 2000
max-ephones 48
max-dn 48
dial-peer voice 100 pots
destination-pattern T
direct-inward-dial
port 0/0/0
voice-port 0/0/0
cptone ES
Can any one help me??
lpezj
Level 7
Level 7
What is your pattern to call outside in CallManager? Do you use a 0 to call outside?
Juan Luis
