QoS - LLQ and using a parent shaper
Matthew burnley
Hi Guys,
Just a quick question about my VoiP config and a Cisco 881.  I am assigning a 500kbps priority queue for voip traffic which is 5mbps.  I'm applying it outbound onthe WAN interface and also using a parent traffic shaper to limit the default class traffic (everything other than voip) to 5mbps - since its a 10 mbps internet connection but the interface is hardcoded 100mbps.  Im using the traffic shaper as i don't see how the router works out how much bandwidth is left after its given the Voip class 5mbps
Does this work as intended or will the traffic shaper limit all traffic (default class and voip) to 5mbps?
class-map match-any voip-class
match protocol sip
match protocol rtp
match protocol rtcp
policy-map PMAP_LLQ
class voip-class
priority 500
set dscp ef
class class-default
fair-queue
policy-map Shape-5Mb-parent
class class-default
shape average 5000000
service-policy PMAP_LLQ
int f0   <wan
service-policy output Shape-9Mb-parent
Francesco Molino
Let recap your official value because there're not matching your QoS config.
Your ISP line is 10m. You want to assign 5m to your voice traffic and then all the rest to your default class. Is that right?
If yes, you have 2 simple ways to do that:
Option 1: Using percent
policy-map PMAP_LLQ
  class voip-class
    priority percent 50
    set dscp ef
  class class-default
    fair-queue
policy-map Shape-10Mb-parent
  class class-default
    shape average 10000000
Interface f0
  service-policy output Shape-10Mb-parent
Output of this config:
sh policy-map interface e0/1
Ethernet0/1
Service-policy output: Shape-10Mb-parent
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: any
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
shape (average) cir 10000000, bc 40000, be 40000
target shape rate 10000000
Service-policy : PMAP_LLQ
queue stats for all priority classes:
Queueing
Class-map: voip-class (match-all)
0 packets, 0 bytes
Match: protocol rtp
Match: protocol sip
Match: protocol rtcp
Priority: 50% (5000 kbps), burst bytes 125000, b/w exceed drops: 0
QoS Set
dscp ef
Packets marked 0
0 packets, 0 bytes
Match: any
Queueing
(queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
Fair-queue: per-flow queue limit 16 packets
Option 2: Using values
policy-map PMAP_LLQ
  class voip-class
    priority 5000
    set dscp ef
  class class-default
    fair-queue
  class class-default
Interface f0
Ethernet0/1
0 packets, 0 bytes
Match: any
Queueing
Queueing
0 packets, 0 bytes
Match: protocol rtp
Match: protocol sip
QoS Set
dscp ef
Packets marked 0
Priority: 5000 kbps, burst bytes 125000, b/w exceed drops: 0
0 packets, 0 bytes
Match: any
Queueing
Your class-map is using nbar and that's fine if your device support it.
However, if you want to take all UDP traffic regarding voice/video if it's not recognized with the match protocol, you can add an acl and add this acl into your class-map: (for simplicity, I used any any but you can also filter with your subnets if you want)
ip access-list extended voip
  permit udp any any range 16384 32767
class-map match-all voip-class
  match protocol rtp
  match protocol sip
  match protocol rtcp
  match access-group name voip
Hope that clarify and answer your question
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
5 Replies 5
Francesco Molino
policy-map PMAP_LLQ
  class voip-class
    priority percent 50
    set dscp ef
  class class-default
    fair-queue
  class class-default
Interface f0
Ethernet0/1
0 packets, 0 bytes
Match: any
Queueing
Queueing
0 packets, 0 bytes
Match: protocol rtp
Match: protocol sip
QoS Set
dscp ef
Packets marked 0
0 packets, 0 bytes
Match: any
Queueing
policy-map PMAP_LLQ
  class voip-class
    priority 5000
    set dscp ef
  class class-default
    fair-queue
  class class-default
Interface f0
Ethernet0/1
0 packets, 0 bytes
Match: any
Queueing
Queueing
0 packets, 0 bytes
Match: protocol rtp
Match: protocol sip
QoS Set
dscp ef
Packets marked 0
0 packets, 0 bytes
Match: any
Queueing
  match protocol rtp
  match protocol sip
  match protocol rtcp
Francesco
Hi Francesco,
Thanks for that. Yes it should be 10mbps ISP CIR connection but its a 100mbps port.  Also yes confirmed i wanted to have 5mbps for voip priority queue and the other 5mbps for everything else.
Just looking at your examples isn't 5000 kbps 5MB's which is 40mbps ?
I have just watched CBT nuggets QoS series Jeremy did a while ago (very good) and noted that he did a very similar example to what im trying to do but he did it slightly different. Basically i created a new class map which contained both the voip class and default class and applied the traffic shaper to this new class map rather than just the default-class as before.
match protocol sip
match protocol rtp
match protocol rtcp
class-map match-all ALL_TRAFFIC
match class-map voip-class
match class-map class-default
policy-map PMAP_LLQ
class voip-class
priority 500
set dscp ef
class class-default
fair-queue
policy-map Shape-9Mb-parent
class ALL_TRAFFIC
shape average 9000000
int f0   <wan
not sure there is a whole lot of difference?
Mbps is megabits per second
MBps is megabytes per second
On IOS, when configuring priority or shape the value is in bits per second:
(config-pmap-c)#shape average ?
<1000-154400000> Target Bit Rate (bits/sec). (postfix k, m, g optional;
(config-pmap-c)#priority ?
<1-2000000> Kilo Bits per second
If you say (and I guess that's the value) you have a 10 Mbps then it's 10000 Kbps or 10000000 bps.
Then 5Mbps is 5000 Kbps.
Is that clarify a bit your question?
The new config you wrote on your latest post (from CBT nuggets), says exactly the same thing as your class-map called on your parent policy refers to your personalized class and class-default.
In your example, doesn't matter which one you use, the result is the same.
Francesco
Hey,
Yes you are indeed correct 5000 kbps is right - thankyou been a long day!
Just one last thing because this QOS it outbound and there is no inbound QOS upstream via the ISP, it does not protect from a saturated link say somebody downloads a huge file?
Would you look at applying the same shaping policy outbound (policy-map Shape-9Mb-parent) on the LAN interface to balance the upload/download?
You can apply the same policy-map inbound if you want.
Francesco
