Quick VOIP Design Question
tholmes
My customer is moving his PBX from site A to site B but wants to keep the PRI30 termination at Site A.
Site A and B are linked by LES100
I think I need to connect a 2651 with VWIC-1MFT-1E at each end, the VWIC at Site A will connect straight into the PRI30 service and the VWIC at Site B will plug into the PBX.
Before I investigate how to configure this, will it work please?
Best Regards Tony
CCNP
jtufail
Yes this should be fine. Both sides connecting with VWICs and IP connectivity between them will have end to end provision ability for voice
Javed
Many thanks for your reply
Cheers Tony
