‎Serial0/x/y:16-30 adminstratively down (show ip interface brief)
m.kuenzler
Level 5
Level 5
Dear all,
The command "show ip int brief" shows the all the interfaces Serial0/x/y:16 - 0/x/y:30 as "administratively down" except from the very first PRI Interface Serial0/1/0:16 - 0/1/0:30.
router#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
Serial0/1/1:0          unassigned      YES unset  up                    down
Serial0/1/1:1          unassigned      YES unset  up                    down
Serial0/1/1:2          unassigned      YES unset  up                    down
Serial0/1/1:3          unassigned      YES unset  up                    down
Serial0/1/1:4          unassigned      YES unset  up                    down
Serial0/1/1:5          unassigned      YES unset  down                  down
Serial0/1/1:6          unassigned      YES unset  down                  down
Serial0/1/1:7          unassigned      YES unset  down                  down
Serial0/1/1:8          unassigned      YES unset  down                  down
Serial0/1/1:9          unassigned      YES unset  down                  down
Serial0/1/1:10         unassigned      YES unset  down                  down
Serial0/1/1:11         unassigned      YES unset  down                  down
Serial0/1/1:12         unassigned      YES unset  down                  down
Serial0/1/1:13         unassigned      YES unset  down                  down
Serial0/1/1:14         unassigned      YES unset  down                  down
Serial0/1/1:15         unassigned      YES unset  up                    up
Serial0/1/1:16         unassigned      YES unset  administratively down down
Serial0/1/1:17         unassigned      YES unset  administratively down down
Serial0/1/1:18         unassigned      YES unset  administratively down down
router#
The config for the serial interfaces are identical except from the clocking (see attached).
Does someone has a clue, why the interfaces are shown as "adminstratively down" and how to correct it?
Martin
5 Replies 5
balaji.bandi
administratively down mean, you need make configuraiton to no shutdown to make it up.
example :
config t
interface serial0/1/1:16
no shutdown
do other interface and let us know outcome.
BB
Sorry, but only the signaling channel is configurable (for PRI E1 this is x/y/z:15). See the output below from my try:
router#conf t
router(config)#int Serial0/1/1:16
%Cannot access B-channel interfaces
router(config)#exit
router#
balaji.bandi
Sorry my bad, i was in impression it was sub interface of serial interface,
Can you post below information :
show run
show controller e1
 show inter s0/1/1:16 (other down interface)
suggested guide for troubleshoot :
https://www.cisco.com/c/en/us/support/docs/wan/t1-e1-t3-e3/14149-chapter15.html
BB
Thanks for your troubleshoot link. I will have a look. The outputs are attached below.
m.kuenzler
Level 5
Level 5
Does no one else have the same issue?
