SIP --> Cisco 5400 --> ISDN - Calling Number Problem
med.saleck
Hi all,
Could somebody please help me in regards to an outgoing calls from AS5400 gateway to the PSTN via PRI.
The Cisco 5400 send the calling number but on my mobile I receive 65535 as calling number for all calls.
I have tried every possible config option for isdn.
Below is a isdn q931 debug of.
Mar 13 22:51:45.256: ISDN Se7/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 249yyyyy
Mar 13 22:51:45.260: ISDN Se7/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 2224xxxx
Mar 13 22:51:45.260: ISDN Se7/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3059
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0180, '249yyyyy'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '2224xxxx'
Mar 13 22:51:45.392: ISDN Se7/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xB059
Mar 13 22:51:45.396: ISDN Se7/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB059
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Mar 13 22:51:45.716: ISDN Se7/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x3059
        Cause i = 0x8090 - Normal call clearing
AS5400 config
dial-peer voice 102 pots
description old_plan
translation-profile outgoing 44
service session
destination-pattern 222.......
direct-inward-dial
port 7/2:D
forward-digits all
interface Serial7/0:15
no ip address
encapsulation ppp
dialer-group 1
isdn switch-type primary-net5
isdn incoming-voice modem
peer default ip address pool setup_pool
fair-queue 64 256 0
no cdp enable
ppp authentication chap pap
ppp multilink
controller E1 7/2
framing NO-CRC4
pri-group timeslots 1-31
trunk-group SM timeslots 1-31
isdn voice-call-failure 0
ADAM CRISP
Level 4
Level 4
Hello, - You should check with the ISDN service provider, but I'd try setting the numbering type to national,
Within your translation profiles you can use the type keyword, and set this,
eg
voice translation-rule 501
rule 1 /^44\(.+\)$/ /\1/ type any national plan any isdn
or similar
Adam
Hi Adam,
Thanks for your reply,
I checked the following:
voice translation-rule 23
rule 1 // // type unknown national plan unknown ISDN
rule 1 // // type reserved plan unknown ISDN
rule 1 // // type international plan unknown ISDN
rule 1 // // type network plan unknown ISDN
rule 1 // // type subscriber plan unknown ISDN
Here an example of of this voice translation rul debug:
Mar 16 17:21:48.455: //-1/B564B436A077/RXRULE/regxrule_subst_num_type: Match Type = unknown, Replace Type = national Input Type = unknown
Mar 16 17:21:48.455: //-1/B564B436A077/RXRULE/regxrule_subst_num_plan: Match Plan = unknown, Replace Plan = isdn Input Plan = unknown
Mar 16 17:21:48.455: //-1/B564B436A077/RXRULE/regxrule_profile_translate_internal: xlt_number=44444444444 xlt_type=national xlt_plan=isdn
Our ISDN provider said that he is not receiving the calling party number.
Saleck
Well you are sending them the something - ask them where the 65535 comes from within their network, check for CLI blocks and if that doesn't work ask for an analyser to be put on the line.. Good luck
this is the CLID configuration:
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
This log from the provider shows that the calling number is received but the problem is user-provided-not-screened.
Can you help about that?
                       ......calling-party-number-1
53>    41   ----0001   ........numbering-plan-identification:isdn-or-telephony-numbering-plan (1)
            -100----   ........type-of-number:subscriber-number (4)
            0-------   ........ext:0x0 (0)
54>    80   ------00   ........screening-indicator:user-provided-not-screened (0)
            ---000--   ........spare:0x0 (0)
            -00-----   ........presentation-indicator:presentation-allowed (0)
            1-------   ........ext1:0x1 (1)
55>    34   00110100
56>    31   00110001
57>    34   00110100
58>    34   00110100
59>    35   00110101
60>    34   00110100
61>    33   00110011
62>    37   00110111
63>    31   00110001
64>    33   00110011
65>    30   00110000   ........number:41444444456
66>    70   01110000 T
67>    0C   00001100 L
