08-01-2006 08:22 AM
I have seen similar messages posted but no clear resolution. We are trying to authenticate two lines to the same ITSP in our lab. The registration process works fine and we can receive calls. The problem comes in when trying to place calls. During the debug session we can see the call failing due to the router not sending any authentication parameters. Any guidance would be appreciated.
voice-card 0
dspfarm
voice service voip
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice-port 0/3/0
voice-port 0/3/1
dial-peer voice 9 voip
preference 5
service session
destination-pattern ..........T
voice-class codec 1
session protocol sipv2
session target dns:sip.labtest.com
dtmf-relay rtp-nte
dial-peer voice 123 voip
preference 5
service session
destination-pattern *123
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 1212 pots
service session
destination-pattern 19725551212
port 0/3/0
authentication username xxx password < >
dial-peer voice 4141 pots
service session
destination-pattern xxx
port 0/3/1
dial-peer voice 411 voip
preference 5
destination-pattern 411
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 911 voip
destination-pattern 911
voice-class codec 1
dtmf-relay rtp-nte
gateway
timer receive-rtp 1200
sip-ua
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers connection aging 30
timers register 250
mwi-server dns:sip.labtest.com expires 1800 port 5060 transport udp unsolicited
registrar dns:sip.labtest.com expires 1800
sip-server dns:sip.labtest.com
08-07-2006 11:24 AM
use the 'debug ccsip all' and the 'show tech' on the gateway which will give you the details about the failure
08-13-2006 09:14 AM
Hi! Actually that is how I know the setup is failing due to an authentication error. It does not seem the VOIP dial-peer is using the authentication parameters from the SIP registration on the POTS port.
