SIP over UDP routing in Cisco 3845
fasil_fcv
dear friends,
How can we configure the SIP over UDP protocol by Cisco 3845 router?
For more details please fine the attachment.
7 Replies 7
fasil_fcv
PBX ( With analog interface) rj11-------------> Cisco router ---------------------------> VOIP
how can we configure router for this type diagram
Have you tried read documentation or use search?
Or even better, engage a reputable consultant, or Cisco partner.
Yes I tried but that is not helpful for me
How can I contact those people (engage a reputable consultant, or Cisco partner)?
Also I tried this commands in below.
voice class codec 1
codec preference 1 g711alaw
dial-peer voice 3250 voip
destination-pattern 3250
session protocol sipv2
session target ipv4:10.156.67.6
session transport udp
codec g711ulaw
sip-ua
retry invite 2
retry response 2
retry bye 2
retry cancel 2
no inband-alerting
sip-server ipv4:10.156.67.6
ip classless
ip route 0.0.0.0 0.0.0.0 10.157.67.1
ip route 10.157.67.0 255.255.255.0 10.167.67.225
access-list 101 permit ip host 10.156.67.1 host 10.156.67.100
access-list 101 deny   udp any eq rip any
access-list 101 deny   udp any any eq rip
access-list 101 deny   udp any eq isakmp any
access-list 101 deny   udp any any eq isakmp
access-list 101 permit ip any any
snmp-server engineID local 000000090200003094202740
snmp-server community public RW
Thelist  cisco partners can be found on cisco.com
For consultants you can try contacting high reputation people on this forum, including myself.
The default codec for a outbound SIP dial-peer is UDP. Unless specified it will answer on both TCP and UDP, but it will always signal via UDP as an outbound initiator unless otherwise specified. Have you verified that the "comm server" or other PBX doesn't require early-offer (SDP in initial invite) or a specific capability or attribute advertised. Have you researched the Cisco UBE Interoperability Portal (Partner Access Only). I agree with Paolo, I would get a consultation from someone, like him or me, who understands Cisco gateways and SIP as a protocol. I wouldn't follow the diagrams with labeling PVDM2-64 for a HWIC module.... I don't always offer early. But when I do, I do so with SDP. Happy normalization my friend.
Nitpick: UDP is not a codec. It is a transport protocol.
Sorry, I did misspeak. I did mean protocol. Thanks for the correction and input on the issue Paolo. But as to the question posed, UDP is the default as stated.
