TCL or VXML Script for Time-of-Day (ToD) Call Routing?
pcantore
I have a fairy basic requirement to implemented an incoming dial-peer that will forward a call to a list of specific destinations (DNs) based on the time of day - e.g. follow the sun scenario for 3 destinations (1 local and 2 remote)!
Can anyone provide a sample TCL or VXML script that could do this based on ToD - ideally using on router's onboard clock!!!
Many thanks in advance... Phil.C
umedryk
Level 5
Level 5
You may not get the tailor made script for this. You can search web for a sample script, tweak some parameters to suite yor requirement.
phershaw
Phil,
Did you manage to find a sript for this ? I have a similar requirement.
Phil
Basicaly no - my research and everyone I spoke to in the know said yes it could be done BUT.....
no-one was actually prepared to share!!! Basically I made a work around by using a script in Cisco Unity Express (CUE). This supports DoW & ToD functionality, but at present requires manual changes for recurring dates as the date is year specific - not to much of a problem you just need to remember to change it each year (bit of a support issue I know).
Why do this? It is actually cheaper to buy an AIM-CUE and write the script (or butcher the AA which now has some TUI management) than to spend the time figuring out how to write this as a TCL script!
Hope this helps.... Phil
