TSP bulk installation
sbuvat
We just upgraded from ver. 3.3(3) to 4.1(2) of CCM. We need to update our TSP on our user desktops.
Do you know if there is a way to massively install TSP without installing the SoftPhone. We are looking for a web based tool like the SoftPhone toll to allows users to easely install and set TSP (mainly for Call Contact feature) Does such a tool exist ?
Thanks for your replies.
Olivier
ebreniz
Level 6
Level 6
Try with Notes directory to pass information to IP Phones through the Cisco TSP.
In the Cisco TAPI solution, the TAPI application and the CiscoTSP are installed on the same machine. The Cisco TAPI application and the CiscoTSP do not directly interface with each other. There is a layer written by Microsoft that sits between the TAPI application and the CiscoTSP. This layer is known as TAPISRV. TAPISRV allows the installation of multiple TSPs on the same machine and it hides that fact from the Cisco TAPI application. The only difference to the TAPI application is that it is now informed that there are more lines that it can control.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guide_chapter09186a008011b3ba.html#xtocid2
