Dear All,
Can you please suggest me what to do to acheive the below setup using Cisco router.
My main objective is to be able to achieve two-stage dialing i.e. dialing into the route using the POTs/PSTN line which would be attached to it, entering the desired telephone number using DTMF, and then having the call sent to our Class 4 softswitch using SIP, for onward termination.
I have been suggested to use either of the below modular access routers with VIC2- 2FXO Card.
- Cisco 2611
- Cisco 2621xm
- Cisco 2651xm
Do you think this setup will work. Will I be able to dial into the router by using the PSTN Line attached to it and then after a announcement/beep or any other indication dial the 2nd number which is our desired number and then that number gets routed to our class 4 switch.
Can anyone explain how this setup will actually work?
Noman
