Two stage dialing using FXO card
NomanPalijo
Dear All,
Can you please suggest me what to do to acheive the below setup using Cisco router.
My  main objective is to be able to achieve two-stage dialing i.e. dialing   into the route using the POTs/PSTN line which would be attached to it,  entering  the desired telephone number using DTMF, and then having the  call sent  to our Class 4 softswitch using SIP, for onward termination.
I have been suggested to use either of the below modular access routers with VIC2- 2FXO Card.
  • Cisco 2611
  • Cisco 2621xm
  • Cisco 2651xm
Do  you think this setup will work. Will I be able to dial into the router  by using the PSTN Line attached to it and then after a announcement/beep  or any other indication dial the 2nd number which is our desired number  and then that number gets routed to our class 4 switch.
Can anyone explain how this setup will actually work?
Noman
paolo bevilacqua
Already discussed in voice forum, please avoid opening duplicate threads.
