Using csim start - call simulation tool
johnyoon75
Hello.
If i make a call using csim start command, i'm sure the simulation work properly or not.
and the error message was displayed.
csim err csimDisconnected recvd DISC cid(9218)
Howc can i troubleshoot this issue?
regard,
john.
venkekri
Csim start should ideally work. Is the gateway H.323 or mgcp.
If mgcp make sure you add destination pattern.
If h.323 then its could be a dial peer issue. Check configuration for that. You can log debug voice ccapi inout and then do a csim start. Once the api timesout, you can do a show log to see what it matched.
Let me know the dialpeers and call flow.
Venky
Thank you for helping.
if i make a call using csim start, the call didn't connect. i don't find any log eventhough i alreday configured debug isdn q931. at this time, if i make call using phone, the call work properly.
i don't think the problem caused by dial-plan.
because i can make a call using normal phone.
john.
