04-25-2006 12:03 AM
Hello There
Is any Prof can help me?
1-Can you please tell me the link where I can get a Voice over IP ISP Design solution?
2-what are the specific requirement for a small startup VoIP carrier/provider.
04-25-2006 12:45 AM
simple questions - no simple answers!
1 - As with any design:
What are your requirements (targeted customers, scalability, features required)?
What are your limitations (cost, time frame, staff,...)?
There is no solution that fits all.
2 - So, what are YOUR requirements? Why do you think VoIP is a good idea in your case? Where is your competition? Which customers would you like to target? What is your budget?
There are many options and first you should narrow your "search space" IMHO.
Regards, Martin
04-28-2006 11:43 AM
Hello Martin
Just a start up basic, no expensive network, with basic equiment for calling card customer.
Thank you very M.
