01-05-2020 05:08 AM
I would like to have 2 VOIP CISCO phones configured in my office. The phones should be integrated with the existing server. Kindly explain what hardware and software requirement does this entail. All suggestions and instructions are appreciated.
Solved! Go to Solution.
01-06-2020 12:17 AM
@IntegratedSolutions75672 wrote:
Do i need a PBX?
If the phones ordered are loaded with 3PCC/MPP firmware, then you won't need a call-controller. All you'll need is a VoIP provider. Please read Cisco IP Phone 8800 Series Multiplatform Phones User Guide.
Can these two phones configured as above setting through wireless?
If the network is set up correctly, yes.
01-05-2020 01:47 PM
01-06-2020 12:10 AM
Appreciate the quick reply. I am new to networking. Kindly explain if more hardware or software is needed. Basically I need to configure two VOIP phones in the office on the same network which are to have extensions to each other. Also the phone should be able to make external phone calls.
Do i need a PBX? Can these two phones configured as above setting through wireless?
01-06-2020 12:17 AM
Do i need a PBX?
01-06-2020 12:24 AM
