Why Loopback required in VOIP Configuration
kuldeeprawat
I have recieved one configuration file.
There the loopback IP is defined whereas it's a point to point connection where i think one serial,ethernet and e1 controller is required.
Can anyone suggest me why this loopback address in being use in the conff...
sh run
Building configuration...
Current configuration : 2375 bytes
version 12.3
hostname rhclvoip
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
username xxxxx privilege 15 secret xxxxx
clock timezone MST -7
clock summer-time MSTDST recurring
no network-clock-participate slot 1
no network-clock-participate wic 0
no network-clock-participate aim 0
no network-clock-participate aim 1
voice-card 1
dspfarm
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip ips po max-events 100
no ftp-server write-enable
voice rtp send-recv
controller E1 0/0
channel-group 0 unframed
controller E1 1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type e&m-melcas-immed
interface Loopback0
ip address 192.168.10.60 255.255.255.255
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FastEthernet 0/0$
ip address 10.10.10.1 255.255.255.248
duplex auto
speed auto
interface Serial0/0:0
ip address 192.168.10.58 255.255.255.252
interface FastEthernet0/1
description uplink to hcl switch
no ip address
shutdown
speed 100
full-duplex
ip classless
ip http server
ip http authentication local
ip http secure-server
control-plane
voice-port 1/0:0
dial-peer voice 61 pots
destination-pattern 7....
port 1/0:0
forward-digits all
sbilgi
Level 5
Level 5
I don't think there is any correlation between the loopback address and the voip configuration. It could have been done for administrative purposes too.
adcoto
Some reasons.
From WAN standpoint, when you have a remote router with multiple links, it is better to point the dial peers to a loopback address. If one of the links die, you still have connectivity to the loopback.
On this example, only one WAN interface, it makes sense to use the loopback if you have voice peers on both sides WAN and LAN.
Assume you don't configure a loopback interface and your dial peers points to Ethernet address. If you loose the ethernet link, you also loose all your voice. Even if the WAN link and WAN voice peers are OK.
The same applies to LAN voice peers pointing to WAN interface.
If you have only one entry interface for voice traffic, adding a loopback interface does not makes sense.
