07-26-2011 12:17 PM - edited 03-21-2019 04:24 AM
First time user on the discussion
Alright - when someone calls into our system, our SIP Provider (Skype) sometimes receives a 410 message from our UC320 and the call will not ring. Now, this is a hit and miss thing so I am unsure why it works sometimes and then others it won't. Has anyone experienced anything like this?
I attached a log file as well in hopes that will be of some help.
Thanks!
07-26-2011 02:59 PM
Can you please send us a screen shot of details of the config for sip in the uc320w.
Dave
07-27-2011 06:44 AM
Below is a screenshot of our SIP configuration (had to take a couple screenshots and combine them into one)
Thanks again!
07-26-2011 03:02 PM
Hi William,
This is the SIP error Message:
Number changed | 410 Gone |
Now the problem is tracking down where the issue is originating from, as much as I would like to blame the UC-320W for it , I am doubtful about it not sending the registration/number info to Skype to maintain registration (But it could be an issue), other than that Skype's SBC might also be dropping the connection as well.
When you say it is a hit and miss, say you receive a call and it works, wait say 30 minutes and try again and they get a 410 error? Or is it really random that it is hard to narrow down on a pattern?
Cheers,
David.
07-27-2011 06:13 AM
David Trad,
When I say it is hit or miss, I mean I can call in and it will give me a busy signal and then I can call in again (5 seconds later) and it will work. It can work 5 consecutive times or it won't work 5 consecutive times. There is no pattern of when it works/doesn't work.
Dave Turner,
I'll provide a screenshot here in a bit
Thank you both for such a fast response!
07-27-2011 03:15 PM
Hi William,
Is there any way you can turn on logging and see if it captures any useful information? It would be good to see what is coming from your end rather than from Skypes end.
Cheers,
David.
07-27-2011 03:35 PM
Also what ADSL router are you using?
DAve
08-02-2011 06:57 AM
Just an FYI on the status of this... I called cisco support on Friday because we were having another problem (not related to this at all) and decided to ask about this as well. They are currently looking at a log of it. I will post the solution once I receive a response from them
