03-09-2010 10:12 AM - edited 03-21-2019 02:16 AM
Quick Question
I see that there isn't any phone load for the 7920 in the flash of the 540, but I do see it in the listed options for phones in CCA. I understand this was EOL a while ago, but will it work with the UC?
Stephanie
Solved! Go to Solution.
03-09-2010 10:54 AM
It will work with the UC. The 7920 firmware is not available in the software packs, but you can manually install the phone load on flash. Let me know if you need help with that.
03-09-2010 10:54 AM
03-09-2010 01:50 PM
Thank you for that, I'll be in touch should I run into any troubles.
Stephanie
