911 Calls Not Working
Jesse Shumaker
what would be the cause for 911 calls to not work? When you dial that number nothing happens.
We have to dial 9 to get an outside line so it's 9911.
Are you fairly comfortable with CLI?  If so, you should see something like this when you do a show run.
voice translation-rule 1112
rule 1 /^9\(.......\)$/ /828\1/
rule 3 /^911$/ /911/
rule 4 /^91/ //
rule 5 /^9/ //
rule 6 /^8/ /00/
rule 7 // //
The dial peers are attached.
7 Replies 7
rowseyba1
Jesse,
Most likely you don't have a translation or a dial peer for 911.  Does it just go to fast busy?
what entries would I need to add 911 as a dial peer or a translation?
rule 4 /^91/ //
rule 5 /^9/ //
rule 6 /^8/ /00/
rule 7 // //
I inputted all of this. thanks
Remember the translation rule is for the 828 area code.  It will add and 828 to any 7 digit phone number dialed.  You will need to change it for your area code.
well mine can be either 602 or 480 so I would prefer that the person types it in. so should I just remove these lines:
rule 2 /^9\(.......\)$/ /828\1/
That is correct.
