AA/Can't input extension for recording prompts
JOHN THIEN
I have a fully updated UC540 running CCA 3.2 (2).
I am trying to enable the AA, and record the prompts.
When I go to the Auto-Attendant/Prompt Management tab, and enter an extension (ANY of my extensions) as the prompt recording extension, it gets circled in red and I cannot save the settings.
I've added prompt administrators.  I've tried just myself, I've tried everyone, I've tried nobody, it doesn't help.
Not sure what I'm doing wrong, any ideas?  Am I providing enough details?
djmohame
Hi John,
Please use the default prompt management extension (397)
Rgards, Jolis
5 Replies 5
JOHN THIEN
Anyone have a solution?  Not sure where I'm going wrong.
djmohame
Hi John,
Rgards, Jolis
Oh!!! I get it, thank you!!!
jeliasoncisco
Level 5
Level 5
Hi. Just to be clear on the answer here. This is because you must specify an unused extension on the system in the prompt management extension field rather that your own. Using any unused extension number has worked in my experience. Please correct me if I am wrong. Thanks.
Hello jeliasoncisco,
You are right .. Each extension in the system should be unique. So you need to use unused extension for prompt management.
