Assigning outbound lines
james.brittain
Hi all,
Im coming to the end of the setup of our UC320w/ spa504G system and having one remaining problem.
Iv successfully setup and assigned inbound lines 5 from sip trunk and 1 from a fxo line.
For reference our 5 in bound sip lines end in 95/96/97/98/99
But all phones start calling outbound on 95 then work up when the lines are busy.
Is it possible to assign each phone its own outbound line?
Cheers in advanced.
fscharz
Hello James,
you can select different outbound trunks but I am not aware of the option to assign to each its own outbound line.
Below is an example how you can select seperate outside lines in the attachment.
Friedrich
